GregValiant 980
That could be a filament brand or water content problem. Some mouse ears might help. There is a Tab anti-warping plugin in the MarketPlace that you can try out. Bring them in and slide them around to provide more bed adhesion at the corners. You would trim them off later.
I designed the mouse ears into this PETG part as I knew it would want to lift. You can see how hard it was pulling and this was with hairspray as well.
You have a big bed. If you were to add a G4 S300 line to your StartUp Gcode right after the M190 bed heating line it would give the bed an extra 5 minutes to equalize across the surface. (The G4 "S" parameter is in seconds).
When my glass bed was new it wasn't as consistent as it is now. You might want to try a glue stick or hairspray to aid adhesion and keep those corners down.
Edited by GregValiant-
1
GregValiant 980
I have the glass build plate on my Ender 3P. I haven't had any trouble with adhesion with PLA. For PETG I always use AquaNet Super Hold hairspray.
You know your printer best so these are just some thoughts rather than suggestions. I'm just looking at the picture and these would be my settings for PLA. I did move to an all metal hot end when the stock one died.
With those numbers and a print speed of 75 - a 220 x 220 x 5 rectangular solid comes out to an 8:32 print.
There is a trick you can play with Accel. If you put M201 X1000 Y500 in your start up gcode then you set the Accel in Cura to 1000mm/sec². That M201 line would limit the Y to 500 and so X moves would be quicker at 1000 but Y only or XY combination moves would be at 500. The printer can live with that.
When you have simple shapes like that you can export them from CAD at a lower resolution. Lower resolutions result in longer line segments in the toolpath and they are more efficient (at the cost of not looking as "smooth" in the print). You could also turn up the "Maximum Resolution" in the Cura Mesh Fixes section.
Finally (I've been waiting to change colors on my current print) a print speed of 5mm/sec at .2 layer height and .4 line width works out to 0.4mm³/sec flow rate through the nozzle. That's just too low. If you are having layer adhesion problems slowing down below 25 isn't going to help.
lcocea 5
To follow up on this, the Ender 3 Max fan is a beast. To avoid warping, I need to turn the fan on at a height of 10 mm or greater (layer 51 in my case). I get good glass bed adherence only if first layer temperature is at least 70 ⁰C. I realize this may be PLA brand-dependent as well so I have to experiment more.
