Thanks - so you think this will print okay and just a bug in the preview view?
After you create the gcode file you can open it in Cura. The gcode reader is a separate program and doesn't have anything to do with the slicer part of Cura. You'll get an accurate representation of how it will print.
It looked fine to me and all that extra stuff was missing from the gcode. Somehow it seems like it's a visualization problem but like I said, chasing it down seems like it's been difficult.
GregValiant 1,488
That bug appears every once in a while and has been documented on GitHub. It's the cockroach bug. You can see it but you can't get rid of it.
This is layer 11. You can see all the lines going back to the origin. They don't actually exist. The upper part of the model appears to have finished and it hasn't started yet. In the Line Type settings - if you toggle "Only Show Top Layers" you can get it to look like it's supposed to.
This is Layer 11 in the gcode file that I opened in Cura. No weird lines and the slider works as it should.
