Replacing second feed motor with 0.2A stepper
Posted · Replacing second feed motor with 0.2A stepper
I am designing an expansion Kit that could allow some new functionality and improved print quality on Ultimaker S3 (later S5).
I need to replace the second feeder motor by a smaller stepper motor rated at 0.2 A.
Any advice on how to reduce the current for the smaller motor?
I will be adjusting the G-code later to use the second feed motor for a different function while the first feeder motor operates normally and prints using core 1 normally.
