Cura Feature request. ADDED BRIM LAYERS.
andrieshjdl
Posted · Cura Feature request. ADDED BRIM LAYERS.
When printing objects with a large footprint I found it VERY beneficial to enable a DRAFTSHIELD with a 1mm to 2mm height, to prevent elephants foot.
Problem is the DRAFTSHIELD  is not always the same shape as the BRIM.
I would like to SUGGEST/REQUEST it be made possible to add a few more LAYERS of BRIM.
If it would be possible to make the inner most line of the brim higher to HELP PREVENT ELEPHANT FOOT.
    There is a lot better chance of developers seeing this on the GitHub page.  If you select "New Issue" you will get an option for a bug report or a "Feature Request".
    Have you tried using "Initial Layer Horizontal Expansion" set to a negative number?  I usually have it enabled at -0.2mm.
    Your build plate temperature can come into play as well.
    I have an air-conditioning vent above my printer and I had to print a deflector for it to keep the drafts from affecting prints.
    When I print with PETG I must use an adhesion promoter (hairspray in my case) and I often need to add anti-warping tabs to the models or they will lift.
        • 6 replies
