Infill like "Grid" and "Lines" and "Triangles" are straight. If you enter different numbers into the "Infill Line Directions" box you can rotate the infill pattern. The default for grid is at a 45° angle to the build plate. If you enter [90] as the line directions then the grid will be square to the build plate.
You may need to select the "Custom" settings view and then click on the icon that has three lines on it and set the setting visibility to "All".
How to Enter
Design an Ornament
Entering a new design
Entering an existing design
Winning designs should:
Be original Creations
Share the creative journey! Include documentation of your design process, giving us a peek behind the scenes. For example, show a screenshot of the model in your design program. Use the Tag Holidays2023.
Make sure your submission aligns with our guidelines and Thingiverse's Terms of Service.
Good luck 🎉
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
GregValiant 1,145
I don't understand.
