How to make my home position at back of bed plate?
Dantech
Posted · How to make my home position at back of bed plate?
Currently, my printer stops at the left front corner after a print which makes it difficult to remove the magnetic bed plate to remove the parts. It also causes difficulty putting the bed plate back on.
How do I make my machine stop at the left rear corner?
I checked my settings in CURA, and the " origin at center" box is unchecked.
My printer is an Ender V2 S1.
Thanks.
    I found and Ender 3 V2 and an Ender 3 S1.
    The basic Ender 3 "Ending Gcode" should do that.  It can be adjusted in Cura.
    Click on "Settings / Printers / Manage Printers" and then click on Machine Settings.
    On the right side of the dialog is the Ending Gcode and this is from an Ender 3:
    G91 ;Relative positioning
    G1 E-2 F2700 ;Retract a bit
    G1 E-2 Z0.2 F2400 ;Retract and raise Z
    G1 X5 Y5 F3000 ;Wipe out
    G1 Z10 ;Raise Z more
    G90 ;Absolute positioning
    G1 X0 Y{machine_depth} ;Present print
    M106 S0 ;Turn-off fan
    M104 S0 ;Turn-off hotend
    M140 S0 ;Turn-off bed
    M84 X Y E ;Disable all steppers but Z
    The bold line is the one you want.  It has to go in after the G90 line.  You could also just copy and paste all of that in.
        • 9 replies
