cura setting idea!
iceman2511
Posted (edited) · cura setting idea!
so when changing the speed of a specific part like the outer wall, usually when you change the print speed it changes along with the outer wall speed as well, but if you have a customised outer wall speed then you have to change that value as well as the print speed value, so my idea is that there should be a setting that changes the speed of a specific part as a percentage of the print speed, so if you prefer to print the outer wall slower than the default 50% to get better print quality, then you can change the print speed value without having to manually change each other value individually to save time and effort and to get better prints.
Edited by iceman2511
