I am using Macs for decades and don't have problems with Cura.
Are you downloading Cura from Ultimaker?
Try to right click the install file and then open, to see if that helps.
I have used Cura on this Mac since early version 3.1 and never had a problem upgrading to newer versions. Version 5.1 is the only one that is causing problems. I think it is something like the issue described in the support document above. For some reason the Mac is unable to check the file for malicious software so it blocks Cura from opening. My version of Cura 4.13.1 still works just fine. Version 5.1 will not open in any way including left click open or any other method. The Mac can't seem to check the file so it is blocked from opening.
Really strange, I am using 5.1 and it is working without any workarounds.
But I am on the latest MacOS, so maybe thats the reason.
ShopGeezer 2
Found this after a search:
https://support.ultimaker.com/hc/en-us/articles/360013828939--Ultimaker-Cura-can-t-be-opened-because-Apple-cannot-check-it-for-malicious-software
I have an older version of the Mac OS (10.13.6, High Sierra) but I suspect it is the same problem. The Mac can't check the program so it won't open it. The work around shown in the help article doesn't work for me. Has this been addressed in the new Beta of Cura 5.1?
