4 minutes ago, GregValiant said:First thing - go to the Mesh Fixes section and see if "Remove all Holes" is enabled. If it is then disable it. It's a specialty setting that (like Make Overhangs Printable) is rarely used.
If it is already turned off then use the "File | Save Project" command and post the 3mf file here. Sketchup is notorious for creating models inside-out and Cura gets confused.
lad im not even gonna lie idk how to even use cura ive been put on the higher course for constrution and this is one of the things i have to do n i have no clue on how to use cura ill try my best tho thanks
GregValiant 1,142
