I use version 4.6.1. The same symptom occurs even with version 4.13.1.
Can someone please share the 3mf file if it succeeds with single wall?
If so, should it be regarded as a bug in the 4.x version?
Is there any way to solve this problem?
Due to other issues I don't use the 5.x version.
Edited by flywork
GregValiant 1,287
I can't reproduce this with just the STL (I used Cura 4.13.1). I ended up with a true single wall print.
In Cura, load the model and set it up to slice and then use the "File | Save Project" command to create a 3mf file. Post the 3mf file here and someone will take a look.
EDIT: I have to take that back. The first slice I did was single wall. I made a couple of changes and the second pass showed up and now I can't get rid of it.
5.2.1 does it in a single pass.
