Settings to print inner and outer object separately ?
XNAc7
Go to solution Solved by ahoeben,
Posted · Settings to print inner and outer object separately ?
Hi everyone, I was trying to slice a clearance test device on CURA. The device come as 2 separate objects, inner and outer object. When I tried to slice it in Cura, it only sliced the outer wall of the outer object. It cannot slice the rest of it. It also happened with other .stl files form Thingiverse. Which setting should I change in CURA ?
    • Solution
    Posted (edited) · Settings to print inner and outer object separately ?
    Looks like you may have "spiralize outer contour" enabled (also known as "vase mode"), or a combination of "remove all holes" and 0% infill. If you save a project and post a link to it here, we can tell you for sure.
    Edited by ahoeben
