Posted · plug in from marketplace doesn't load
Recently upgraded to Cura 5.2.1 from 4.13 and tried to install the Cylindrical Custom Support (CCS) from the marketplace.
-Removed 4.13 and installed 5.2.1, opened
-Installed CCS from the Marketplace Icon
-Shut down and restarted Cura
-Opened a .stl file and clicked on it
-No icon on the left to create the supports like there was on the previous version. (When I look again in marketplace, my option is to uninstall so I assume it is loaded correctly.)
Did I miss something?
Thank you,
Phil
    Sometimes when upgrading plugins, Cura seems to think that it has installed the plugin but really didn't. Please try the following:
    * Uninstall the plugin from Cura 5.2 via the Marketplace dialog.
    * Close and restart Cura (this step is important!)
    * Install the plugin again via the Marketplace dialog
    * Close and restart Cura one more time (sorry)
    If that does not help, we are going to have to see the Cura.log file from your configuration folder (see Help -> Show configuration folder).
    • 4 weeks later...
    I have a similar issue to Philler.  I go to the MarketPlace to install "MeshTools 3.7.0", I click on the Install but it never installs or changes the "Install" button to "Uninstall".  I have restarted Cura, checked the "Extension" list to see if it is there and it's not listed.  Also tried a different Plugin "Auto Orientation 3.7.1" that also did the same thing.
    I have attached my log file.
    Thank you in advanced.
    cura.log
