GregValiant 1,309
So you would start Cura and select a folder. Then your automation would:
- Load a model.
- Slice
- Save the gcode
- Clear the build plate
- Repeat
The problem I see is a lack of quality control. If there were problems you wouldn't know about it until the print at least started. That could happen 152 times.
Foxtrix 1
Yea, I would just change all the STL files into one cura profile that I would make.
