The plugin can be found in the plugins folder inside the installed application folder. It is named VectorReader. However it will not be possible to simply drop it into Ultimaker Cura 5.x.
The plugin is not compatible with new versions of Cura; it is not clear what version of Cura the creatwit thing is based on so which version of Cura might work with the plugin. The plugin requires at least one dependency that does not ship with Ultimaker Cura ("cbd", I can't find any information on it, it may be custom code).
Without a link to the source code - which by the way Creatwit3D are required to give to you if you ask them - there really isn't all that much that you can do.
Edited by ahoeben
ahoeben 2,047
Edited by ahoebenLink to post
