3 hours ago, GregValiant said:I hate being yelled at. Try to calm down.
Go to Thingiverse.com and pick a simple model like a calibration cube.
Extract the files from the zip folder.
Start Cura and open an STL file that you downloaded.
There is a big blue button in the lower right of Cura that says "Slice". Click on it.
Once it slices that button will change to "Save to disk". Save to disk.
Copy the saved gcode file to an SD card
Stick the SD card in the printer.
On the printer there will be a command like Print from TF. Select that.
sorry, but I probably put it wrong, how to divide the stl model into several parts (since there is no way to print it in its entirety) is it possible to do this?
GregValiant 1,330
