Windows 11 file type association problem
JonasGrumby
Go to solution Solved by JonasGrumby,
Posted · Windows 11 file type association problem
I'm unable to create file type associations for .gcode and .stl using Cura 5.2.1 on Windows 11. I have tried using Setting > Apps > Default Apps and I have tried right-clicking a file and choosing "open with". I have set Cura as the "default app" and still when I click one of these files it doesn't launch Cura. Instead I get this dialog box and clicking "Just Once" also doesn't launch Cura. Also the Cura icon is not displaying correctly in the dialog. Any ideas? Thanks.
    • 4 months later...
    • Solution
    @eremef
    Thanks. It's not that simple. It's a registry problem. I had to run a run a .reg file like this. I have to do it again now that Cura v6 is out...
    Windows Registry Editor Version 5.00
    [HKEY_CLASSES_ROOT\.stl\OpenWithProgids]
    ".stl.4.13"=-
    [-HKEY_CLASSES_ROOT\.stl.4.13]
    [HKEY_CLASSES_ROOT\.stl]
    @="Cura.model"
    [HKEY_CLASSES_ROOT\Cura.model]
    @="Standard Tessellation Language (STL) files"
    [HKEY_CLASSES_ROOT\Cura.model\DefaultIcon]
    @="C:\\Program Files\\Ultimaker Cura 5.2.1\\Ultimaker-Cura.exe,0"
    [HKEY_CLASSES_ROOT\Cura.model\shell]
    @="open"
    [HKEY_CLASSES_ROOT\Cura.model\shell\open]
    @="Open with Ultimaker Cura 5.2.1"
    [HKEY_CLASSES_ROOT\Cura.model\shell\open\command]
    @="C:\\Program Files\\Ultimaker Cura 5.2.1\\Ultimaker-Cura.exe \"%1\""
    [-HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.stl]
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.stl\OpenWithProgids]
    "Cura.model"=hex(0):
    Posted (edited) · Windows 11 file type association problem
    Solved:
    I used Ctrl+F to Find all instances of "Cura" in the Registry Editor.
    In every case where 5.3.1 existed along side 5.4.0, I deleted the 5.3.1 version.
    In every case where 5.3.1 existed without a 5.4.0 equivalent, I modified it by only changing the "3.1" to "4.0".
    This worked for me without doing anything additional.  Good luck.
    Edited by lee-EB
    I resolved the issue.
    I did something similar to Jonas' solution above by verifying the existing registry entries. I saw that some looked weird, deleted those keys, downloaded the .MSI install and reinstalled. It works now.
