1 hour ago, GregValiant said:If you were to use Support Blockers you could eliminate the support structure under some areas. Tree supports generally take up less space on the build plate.
It's hard to tell without seeing the model and what you are really trying to do. A picture is still worth a thousand words.
Thank you for your response. I include a picture of my model. Of course one way to reduce support is to choose an optimal position of the model on the build plate. But I still would like to reduce the support structure. I looked into tree support, it may help somewhat but Cura still generates a continuous support structure below the horizontal model element. It might have generated a number of trees below it.
Edited by michielper
Included comment on using tree structure.
GregValiant 1,316
