I have no other extensions running
GregValiant 1,364
Post a gcode file that shows that behavior and someone will take a look. At every layer in the gcode there should be a line like:
M117 Time Left 0h21m35s
Is that the format you are used to seeing (Time Left 0h21m35s)?
GregValiant 1,364
Do you have other post-processors active? They run in the order they are listed. If you have others active then maybe one of them is over-writing the M117 line in the gcode.
