Posted · All "5.X.X" versions of Cura crash a lot (OSX 12.4)
I have a little annoying problem where all versions of cura 5 and up crash a lot. The Creality slicer never does this and Cura versions below 5 dont seem to either. Any thoughts? I did once have chitubox installed, which I know can cause problems, but I got rid of it and did a fresh install of Cura for version 5.2.1 after.
Here's what I'm getting as an error i case anyone can lend a little insight, thanks! :
Traceback (most recent call last):
File "UM/Qt/Bindings/MainWindow.py", line 273, in resizeEvent
self._updateViewportGeometry(win_w, win_h)
File "UM/Qt/Bindings/MainWindow.py", line 321, in _updateViewportGeometry
view_width = round(width * self._viewport_rect.width())
ValueError: cannot convert float NaN to integer
Thread 0x000070001f3d4000 (most recent call first):
File "/Applications/Ultimaker-Cura.app/Contents/MacOS/share/cura/plugins/USBPrinting/USBPrinterOutputDeviceManager.py", line 88 in _updateThread
File "threading.py", line 946 in run
File "threading.py", line 1009 in _bootstrap_inner
File "threading.py", line 966 in _bootstrap
Thread 0x000070001e3d1000 (most recent call first):
File "/Applications/Ultimaker-Cura.app/Contents/MacOS/share/cura/plugins/RemovableDriveOutputDevice/RemovableDrivePlugin.py", line 61 in _updateThread
Thread 0x000070001d3ce000 (most recent call first):
File "threading.py", line 324 in wait
File "zeroconf/__init__.py", line 2534 in wait
File "zeroconf/__init__.py", line 1715 in run
Thread 0x000070001c3cb000 (most recent call first):
File "threading.py", line 600 in wait
File "/Applications/Ultimaker-Cura.app/Contents/MacOS/share/cura/plugins/UM3NetworkPrinting/src/Network/ZeroConfClient.py", line 81 in _handleOnServiceChangedRequests
Thread 0x000070001b3c8000 (most recent call first):
File "zeroconf/__init__.py", line 1369 in run
Thread 0x000070001802a000 (most recent call first):
File "threading.py", line 320 in wait
File "threading.py", line 460 in acquire
File "UM/JobQueue.py", line 98 in _nextJob
File "UM/JobQueue.py", line 124 in run
Thread 0x0000700017027000 (most recent call first):
Thread 0x0000700016024000 (most recent call first):
Thread 0x0000700015021000 (most recent call first):
Thread 0x000070001401e000 (most recent call first):
Thread 0x000070001301b000 (most recent call first):
Thread 0x0000700012018000 (most recent call first):
Thread 0x0000700011015000 (most recent call first):
Current thread 0x00000001056d9600 (most recent call first):
File "cura/CrashHandler.py", line 397 in _logInfoWidget
File "cura/CrashHandler.py", line 182 in _createDialog
File "cura/CrashHandler.py", line 86 in __init__
File "cura_app.py", line 165 in exceptHook
File "UM/Qt/QtApplication.py", line 416 in exec
File "cura/CuraApplication.py", line 897 in run
File "cura_app.py", line 239 in <module>
    Hey @widdershins,
    Welcome to the Ultimaker Community 🎉
    We have a known issue with crashes that happen with some models that are perfectly in the middle of the buildplate. If you move the model away slightly from the center of the buildplate you should be able to slice. Could it be that you are experiencing the same?
    We are collecting cases here so the developers can solve the issue better.
    https://github.com/Ultimaker/Cura/issues/13643
    Do you have a project file for us? It contains the printer and settings we need for troubleshooting.
    To save a project file go to File -> Save project.
    • 3 weeks later...
    The ValueError: cannot convert float NaN to integer raised because of Pandas doesn't have the ability to store NaN values for integers.
    From Pandas v0.24, introduces Nullable Integer Data Types which allows integers to coexist with NaNs. This does allow integer NaNs . This is the pandas integer, instead of the numpy integer.  So, use Nullable Integer Data Types (e.g. Int64).
    df['x'].astype('Int64')
    NB: You have to go through numpy float first and then to nullable Int32, for some reason.
    Another solution is Using numpy.nan_to_num().  The numpy.nan_to_num() returns an array or scalar replacing Not a Number ( Not A Number ) with zero, positive_infinity with a very large number and negative_infinity with a very small (or negative) number.
    If you are not satisfied with the above solutions, you need to say what you want to do with NANs . You can either drop those rows df.dropna() or replace nans with something else (0 for instance: df.fillna(0) )
