Holes in crav5
Leggy
Posted · Holes in crav5
Hi all I’ve been using v5 for a few weeks and am impressed
one problem I have come across is this. I drew a phone case with a cut out on the back of Iron Maiden
I printed it and it printed a solid case,even the camera hole was solid
so I thought I would do a simple test , drew a 50 x50 x2 square and put a 40 mm hole in it , again came out solid
Today I put an object in the slicer the part has 3 holes in the top layer 10 mm deep, I can see the holes . I slice it
and they disappear just a solid top
Anyone else experienced this
Thanks Dean
    Found it !!!!!!! That was it thanks
