Thanks for your response...
I just discovered, via a YouTube video, the Market Place "Settings Guide" plugin. It explains each setting verbosely.
Interactions: Normal wall print speed and bridge wall speed. The greater the difference between them the harder it becomes to control filament flow. The same is true when adjusting bridge flow rates, the greater the difference between the preceding flow rate and bridge flow rate the harder it becomes for the extruder to succeed.
It would seem reducing flow rate differences is a key factor. Therefor would it not make sense to compensate while approaching a bridge segment by slowing down thereby reducing the flow rate change. It looks like bridge coasting intends to do this. But why wait until one is about to bridge a gap. It would make more sense to gradually change both speed and flow rate before approaching a gap. Thereby keeping flow rate within extruder capability.
If you have not already done so, consider adding the Market Place "Settings Guide" plugin.
Edited by Dana1960
GregValiant 1,492
I think there are a couple of things going on.
With your line width at .48 and the Skin Density at 100% the two outboard bridge extrusions are getting welded to the inner wall extrusion making it 3 extrusions wide.
You could drop the Bridge Skin Density to 60% or so to spread the lines out. That would eliminate the triple line on the outside. The Flow rate could be adjusted as well but too low and the printer won't like it.
