I've pasted in the ending code below from Cura. There seems to be no additional ending code from Octoprint from what I can tell. It has a similar option for ending code which is currently blank. The head dropping persists even when taking Octoprint out of the equation (ie. sneaker net using SD card) albeit in different spots as outlined in my original post. If Cura is ruled out I'll move to troubleshooting Octoprint next I suppose.
I've attached two g-code files based on the same model. One printed direct via SD Card and one printed via Octoprint. Both were created in Cura without any changes in between.
Thank you in advance for any help you can provide.
G91 ;Relative positioning
G1 E-2 F2700 ;Retract a bit
G1 E-2 Z0.2 F2400 ;Retract and raise Z
G1 X5 Y5 F3000 ;Wipe out
G1 Z10 ;Raise Z more
G90 ;Absolute positioning
G1 X0 Y{machine_depth} ;Present print
M106 S0 ;Turn-off fan
M104 S0 ;Turn-off hotend
M140 S0 ;Turn-off bed
M84 X Y E ;Disable all steppers but Z
CE3E3V2_DanaFrame_Stack_direct.gcode CE3E3V2_DanaFrame_Stack_Octo.gcode
GregValiant 1,342
In Cura go to "Manage Printers" and then "Machine Settings". In the "Ending Gcode" window will be the end of print commands. I don't know how you have configured Octoprint but generally it's the Ending Gcode that finishes up a print.
I have seen some printer definitions that include a G28 line in the Ending Gcode. That's a bad idea as it will drop the head.
Post a Gcode file that shows the problem. The "drop the head" move will either be in the Ending Gcode or there may be some sort of configuration in Octoprint (which I have no experience with).
