If you are using "Pause at Height" then you have at least two options regarding the actual Pause command.
"M0" is the normal Marlin command and should send the message "click to resume" to the LCD. When you are ready to restart then a button click on the LCD should resume the print.
An alternative is "BQ/M25". The M25 is "pause SD print". Sometimes the LCD will say "click to resume" but sometimes (depending on your firmware) you may need to click on "Pause" before clicking on "Resume".
How the printer reacts to a command is a function of your firmware. If a command is not supported by the firmware then it is usually just ignored by the printer.
Grazie mille....... probabilmente e questione di firmware perche sul display non compare nessun comando. mi resta solo di mettere in pausa manualmente😪.. ciao e dinuovo grazie !
GregValiant 1,319
Baribas 0
