error installing ultimaker cura 5.2.1 on windows 10
Go to solution Solved by MariMakes,
  • Solution
Posted · error installing ultimaker cura 5.2.1 on windows 10
Hey @ram110620112,
Two things you can try jump to mind:
1. Can you check C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ultimaker Cura and see if you have any old installations of Cura that might not be completely removed?
2. A more extreme way is to do a clean install. WARNING: You will lose your printers, and profiles if  you do this. You can find instructions how to do that here: https://support.makerbot.com/s/article/1667337567843
4 hours ago, MariMakes said:
Hey @ram110620112,
Thank you sooooooooooooooooooooooooooooooooooooooooooo much!!!!!!!!!!! you dont know how much you have helped me!!!!!!!!!!!!!!!!!!!!!!!
