There is no way to get two lines between the walls?
Then i have to use pre arachne version 😞
GregValiant 1,364
I liked 4.13.1. It's very stable and worked well for me.
In the end though, if the gap is full of plastic it's full of plastic. You can only see it when it's printing. Functionally have you noticed a difference? I don't really see one.
When i have 2 lines i have no travelmove
Its like vasemode
In Arachne i cant set a continuous innerwallprinting and slicer makes travelmoves.
Every travelmove i dont have to make i have less stringing. I have to do less settings and less failuer can appear.
- Solution
GregValiant 1,364
Ok, will try it
GregValiant 1,364
There is no Max value. The reason for that was technical and so I immediately forgot all the details.
You can set the Minimum in the Wall Settings / Minimum Wall Line Width. Cura seems to respect the Minimum. There may be side effects to that (like maybe with Print Thin Walls).
