Layer ends move upwards on layer change
tryptamine
Posted · Layer ends move upwards on layer change
IMG_20230119_130556.thumb.jpg.072450b455aff556fc6930bade11818e.jpgIMG_20230119_130549.thumb.jpg.3d45a87f01028ddbbaf00bd36e09d341.jpg
I do not understand why on some prints, the layers deform upwards where the z seam is. on other prints, this is not the case:
even though this little thing was printed at very high speeds.
The first print is simply a cylinder, the 3MF here:
LayerUpwards.3mf
My configuration here:
BugLayer.curaprofile
I played around with Wipe Distances and Coasting but i simply can not resolve this.
Any idea which setting in my profile could be causing this?
Printed on a Hypercube Evolution with Bowden setup.
