Extremely anoying interaction between bridge settings and modifier mesh.
Xaxina
Posted · Extremely anoying interaction between bridge settings and modifier mesh.
Hello everyone.
So I have spent an entire day trying to get this to work.
I have a model that i want to print.
The 2 requirements are, the model has to have fuzzy skin on the outside (and only outside), and it has to have very specific  and very slow bridging parameters
since i use a 0.8 nozzle with PETG.
I want the model to have fuzzy skin on outer walls, however since the model has holes, if i click fuzzy skin on outer walls only i still get the texture on the inside.
Simple solution, i make a modifier mesh, reduce X/Y size just a bit and i turn off fuzzy skin on it.
And boom!
Great!
Now all that's left to do is set the general bridging parameters.
And this is the result...
If i try to use bridge settings, for some reason, it treats all the walls that are inside the modifier mesh as bridges.
My normal bridge speed is like 5mm/s meaning this model takes YEARS to print.
Ive tried using the same settings on only the modifier mesh, and the result is the same.
I tried making another modifier mesh with just bridging parameters, and it doesn't work.
I tried everything i could think off and it still detects everything inside the modifier as a bridge.
Could someone please help, Im losing my mind :).
Thank you.
    Load the model and set up your slice.  Use the "File | Save Project" command and then post the saved 3mf file here.  Somebody will take a look.
