Thank you for the details 🙂.
It seemed like it struggles to place multiple objects if there is much conflict unlike DeepNest which it now sounds like is based on the same library. I am not saying DeepNest is a standard to meet, I was using it for a laser cutter layout and noticed it took a different approach and ended up with a different layout that did not need to be manually completed.
Thank you again for the great tool. We all appreciate all of your hard work.
nallath 1,123
The library that we use is already based on the work done in svgnest.
Any improvement in the nesting won't have any influence on the tree support (or the generation thereof).
