What the Back-up plug-in does is create a copy of your configuration folder and load it when requested.
You can do the same without the back-up plugin!
Go to Help at the top bar of Cura
Select Show Configuration Folder
Select all the folders in there and create a zip OR go up a folder in your folder structure and zip your folder with the correct Cura version
Load the zip folder on an USB
Open the Cura configuration folder on your new computer
Load the contents of your zip folder on the new computer
That is a method I use for troubleshooting other people, when I need to make sure I have the same plug-ins, materials and profiles loaded.
MariMakes 168
Hey @3D_RedPlanet,
This is what you will be moving over:
Hope this helps 😊
3D_RedPlanet 1
Hi, and thank you so much... this is exactly what I was looking for.
I hope others will benefit from this answer as well.
Thank you!
