Print only partially connects over network
Posted · Print only partially connects over network
Hi All,
I have an S5 that has been set up and running for several years.  It was configured to run on local network.  I could connect to it thru cura, "print to network", monitor it thru cura and the browser.  However, since I got back from the Christmas break, some functionality has been lost.  In Cura, it still detects the printer on the network, but if I hit connect, it grays out for about a second, like it is trying to connect, then goes back to unconnected status.  This means no "print to network" and a blank monitor tab.  If I try to connect to it thru the browser, I get the standard welcome screen.  It I hit temperature graph, it will display the graph with live data properly, but if I hit digital factory, it just loads and loads but never connects.  Connecting to the web cam directly thru port 8080 also works.  At this point I am stuck saving new prints to USB and printing that way and lose all remote monitoring (minus webcam) and control.
