Thanks, each profile have slightly different settings like e.g a higher fill percentage. I did find the file, I suppose that I have to set the "settable_per_extruder": false to true, to become active.
A very interesting file, I did also see that you can set sharing a nozzle. I have a heatblock with two feeds for filament and one nozzle. Does it mean that I have to set sharing nozzle to true when I want to mix two colors?
GregValiant 980
Nope.
From the base printer definition file "fdmprinter.def.json":
"adhesion_type":
"label": "Build Plate Adhesion Type",
I guess I can see what you want. If you have 3 different custom profiles that were identical to each other except for the Bed Adhesion extruder then that would be about the same thing. It's one mouse click to set it, but that's what you have now.
