How do I change the default Temp of PLA in Cura
Posted · How do I change the default Temp of PLA in Cura
Ok I just got my printer Monday even and it took must of the night to get it leveled just right. It was one thing after another, but finally I got it to print without the filament wrapping around the nozzle. the only thing is, Now I'm seeing the filament is curling up a little bit at the base of the print before it even gets a mm high! I heard if the build plate isn't hot enough then it will start to adhere or can curl.
Right now, the default for the plate is 50C but I'd like to get it high. I've change to temp in preheat but then the file freezes and nothing prints. Or, most of the time, it just drops back to the default temp.  I'm still new to Cura and not really sure where everything is on it. Can anyone help?
