for now, I just added additional thickness on the walls and at least I am not able to break it by hand. Didn´t try yet to install it on the machine. Thank all for the inputs
dsp 18
printing under an angle usually helps to get strength in all directions but support is needed
If I understand correct your making a catch out of these two brackets, how heavy is the product falling through?
I would try and place it with the big flat under a 45° angle with the with the build plate.
With the 90deg angle placed on the buildplate, but printing with the same geometry as a steel part isn't always the best solution.
tomnagel 126
Do you have more room on one side maybe? Adding strength and stiffness can also be done by the geometry. "Just" make it more bulky.
MPestana 2
