Supports are not touching 3d model
Schmordan
Posted · Supports are not touching 3d model
I'm a bit new to 3D printing and have printed a few things but I'm having an issue where when generating supports, the support itself is not touching the model i'm trying to print. I've tried settings like 'Z overrides X/Y' and changing Support Z Distance, but nothing seems to work. I'm using Cura 5.2.2 Plz help
the model I'm trying to print:
FilamentGuide_v2.5.stl
    Based on the screenshot of your gcode preview.. the support is working as intended..
    It should honestly never be directly printed on unless your using PVA material as support.
    What is the issue with the print its generating? do you have pictures of the print?
    I am glad it printed successfully. 😃
    Though I am confused as to what was wrong with the layer preview?
    It appeared as expected to me 🤔
    I'm a bit confused as well. I used Support Interface and when switching layers between the layer the support is printed and the one before, there was a one layer gap between the print and the support.
