Will Cura ever support more than two filaments/tools?
Posted · Will Cura ever support more than two filaments/tools?
I have used Cura from the beginning and have really dialed in my settings.
When I added a multi-color adapter I had to start using another slicer because Cura would only support two tools.
Please add to the wish list!
    Posted (edited) · Will Cura ever support more than two filaments/tools?
    Yes. Cura already supports at least 8 extruders. However, if the printer definition you use says that the printer only has 2 extruders, Cura will offer up to 2 extruders.
    If you add for example a Custom FFF Printer, you can select up to 8 extruders.
    Cura has the philosophy that if you can mod your printer, you can also (learn to) mod your printer definition.
    Edited by ahoeben
