GregValiant 1,364
Hi @Dustin and @ZeitRapha,
This "incomplete raft" problem has been reported at least a couple of times on Github (#12276 is one and #13696 is another and it's on the Cura backlog at CURA-9349). I noted in one of the Github reports that moving the model away from the mid-point of the Cura build plate fixed the issue.
Dustin 161
From the picture it looks like you might have some hardware issues.
There is a lot of under extrusion all over the print not just the raft.
