GregValiant 980
In regards to the speed, you are probably bumping up against the "Minimum Layer Time" which has a default of 10 seconds. You can set it lower but the print may not have a chance to cool properly before the nozzle comes back around. A related setting is Minimum Speed. The settings are in the Cooling section.
Unless you intend to print a lot of models that have single walls and need the walls to be some exact thickness, don't calibrate using a single wall model. Just calibrate the E-steps and you are done.
The best way to tell if you have the flow dialed in is to use a decent magnifying glass and check a top skin.
Xeddog 6
Sheez. Already have an update.
I just happened to watch this one start printing. The first layer printed at the 30mm/s as defined in my Cura settings. As the second layer started, I heard the fans come on, and the print speed DECREASED even further. Like maybe 10mm/s.
