2 hours ago, Cuq said:Not a Bug just a normal behaviour for Cura as well for OpenScad. If you want to get a complete Cube and a complete text your must generate 2 models and merge them into Cura .
Thank you for this hint! I have created 2 models, put them together and now it prints like it should.
Cuq 205
GregValiant 1,330
@MarioLange1983 if you scale your model up in the X and Y to about 150 x 150 I think you will get a better idea of what is going on. Because it's a single model the infill from the lower cube is going up into the "A". That results in a gap in the skin so the infill can keep going.
You can try setting the "Skin Expand Distance" to a higher number so it closes the gap where the infill sneaks through.
MarioLange1983 0
This answer makes things clear. I did not thought about the fact, that the infill also goes into the "A". I will test the "Skin Expand Distance" settings, for now the answer from @Cuq was working for me like i think it should!
