Noctua 40mm are silent, powerful and come with a 2 to 3 pin adapter.
Not exactly cheap ($15 US) compared to other fans this size but worth it.
Thanks for the info, I ordered the Nuctua,
lets hope they are as silent as they claim
Got the two Nuctua fans today, and they are really quiet (and expensive), and work great,
they give a little less air then the stock 50mm fan, but that was to be expected, but now I have two fans instead of one.
thanks guys
Looks really nice! Did you discover any down sides by now?
It's this model right? http://www.idealo.de/preisvergleich/OffersOfProduct/3600422_-nf-a4x10-flx-40mm-noctua.html
I'm think about purchasing this setup as well.
Yes those are the ones, I have not had any problems, but I still have to test if the fans blow enough air.
because they are silent you don't hear the rush of air
and the fan-ducts are not as close to the nozzle as the older one was, this could also impact the amount of air flow close to the nozzle.
I am doing a test right now with a Non Vase
http://www.thingiverse.com/thing:31206
3dcase 37
Hi Xeno,
here in Tilburg we have Piet Knowledge on the Korvelseroad, ( A.k.a. Piet Kennis), most electronic shops will have them I guess, or Conrad?.
Take care with the dimensions. Check for yourself on the counter, or the datasheet online.
Some confusion.. 40mm FanHole, 40 mm Oustside square, 40mm square boltpattern?
Took me two ride's to get the right ones :(..
