BugCura (4.12.1) doesn't set bed temperature in gcode (M140) when it's set to 0 degrees, which causes some printers to use their default temperature instead
Posted
· Cura (4.12.1) doesn't set bed temperature in gcode (M140) when it's set to 0 degrees, which causes some printers to use their default temperature instead
Are you sure you are on Cura 4.12.1?
That version is from October 2022.
There have been a lot of improvements made since that release.
We have a number of settings that "turn off" when you set the value to 0.
There are a lot of cases where that's beneficial because "cool" often means room temperature, and that varies depending on your country and the season. I wouldn't be surprised if that's also the case for this setting. It's unfortunate your printer interprets that as 70 degrees, other firmware versions chose to ignore it.
Is setting the value to 1 instead, a better solution in your case?
Or should matching your room temperature be a better solution?
Hope this helps 👍
MariMakes 208
Hey @AlteriusOmega,
Hope this helps 👍
