Uneven Gantry Height
Posted · Uneven Gantry Height
Hello, I am relatively new to 3d printing. I go a Longer LK5 Pro about a year ago and I have a problem where the powered side of the gantry goes up the correct height, but the right lags behind (see image), which usually leaves unsatisfactory clearance and/or surface finish. I tried experimenting with different belt tensions and changing the eccentric bolt on the gantry wheel, but nothing has really worked well. Is there a way I can fix this without making significant modifications?
    Hi MrBeantown, Sorry to hear your having issues with your Longer LK5 Pro.
    However, you might get better support for your printer reaching out to Longer or its user communities.
    UltiMaker is not associated with Longer in any way.
        • 28 replies
