Posted
· Problem with printing a .stl file using Cura
The Ultimaker 2 (and newer) printers don't officially support printing via USB. If you want to print via USB anyway, you have to change the GCode flavor from "Ultimaker 2" to "Marlin". This will - among other things - let you select materials in Cura instead of on this printer. It will also add a start gcode snippet to the gcode, which is missing with the "Ultimaker 2" flavor.
ahoeben 1,981
