Feature request under "z seam": limited random start location
sricha
Posted · Feature request under "z seam": limited random start location
Hello.  First, thanks to all of you for all your hard work!
I have a feature request to add an additional selection in the "z seam" section that is identical to "random", except it limits the travel from the end of the last perimeter to the start of the next perimeter.  Presently, with "random", the start start of the next perimeter is chosen to be a random location along that perimeter.
With "limited random", the start of the next perimeter would be chosen to be a random location within a "d_mm" radius of the nearest location of the next perimeter to the end of the last perimeter.  Of course, "d_mm" would be a user defined parameter which would probably be in the range of 10-25mm.
So that way, the travel move to the start of the next perimeter would either be no more than 10-25mm from the end of the last perimeter, or at most, no more than 10-25mm from the shortest possible travel to the next perimeter.   This should save time (compared to random) and result in slightly less oozing and blobs.
I hope that made sense.  If there's a combination of settings that already accomplishes that goal, then that would be even better!
Thanks,
Scott
    Im not sure I follow the reason for needing that?
    It sounds like "Shortest" "Sharpest Corner" or even "User Specified" would result in mostly the same results.
        • 27 replies
