under extru below 4mm3/s
Posted · under extru below 4mm3/s
HI All, Started new topic as been a few days without response on the previous thread, feel free to delete last.
I ran illuminati's under extrusion test. Result is here. Could someone help me get my UM2 upto the 8- 10 range described as "normal"
Thanks in advance,
IMAG2944IMAG2947
    What does your PLA look like once it has cleared past the feeder knurled knob? I found PLA that PLA by some manufactures would cause to much drag, especially with the knurled knob imprints.
    IMG 7625
    IMG 0044
    I went in and cut a few mm off of the feeder pressure tension bar so it would have some play to allow the screw to operate. I now get much further up the extruder test print but I have to raise the temp to 240 to get past 9
    IMG 7634
