Thanks for the reply.
BTW, I might have found the solution...
In this link, using "Slicing tolerance" parameter and set it to "Inclusive" may do the trick. I'm going to give it a go and I'll come back with the results shortly.
BTW, it's kind of a strange "accuracy" issue after all the printer was printing find apart from that offset, i.e. look at the following examples of what use to happen:
- Ex 1: Cube 10x10x10mm would print 10.4x10.4x10mm;
- Ex 2: Box 60x60x10mm would print 60.4x60.4x10mm;
and now it prints:
- Ex 1: Cube 10x10x10mm would print 10x10x10mm;
- Ex 2: Box 60x60x10mm would print 60x60x10mm.
Thus, the scale factor can't really be applied...
Horizontal expansion may be a workaround - another test for me.
If the models are consistently printing 0.4mm too big regardless of the size of the model then yes, the shrinkage settings won't help. Actually scaling the model in Cura is still an option as you can set the actual dimensions (rather than setting a percentage).
If there was a problem with the steps/mm of your steppers then that would show up as a "scale" issue as the error would be cumulative over any distance.
The more I think about this the odder it seems. Load a calibration cube and use the "File | Save Project" command and post the 3mf file here. It could well be a setting issue.
Check your printer's firmware settings: Make sure that the steps/mm values for each axis are correct. These values determine how many steps the motors need to take to move the axis a certain distance, so it's important that they are set accurately. You may need to adjust these values after making changes to the printer's hardware. Calibrate your extruder: The extruder is responsible for pushing filament through the nozzle. If it is not calibrated correctly, it can lead to under or over-extrusion, which can affect the dimensional accuracy of your prints. Adjust your print settings: In Cura, you can adjust various print settings that can affect the dimensional accuracy of your prints, such as the extrusion width and flow rate. Experimenting with these settings can help you achieve better accuracy in your prints. Consider designing your parts with a smaller tolerance: If you are having trouble with parts coming out too large, you can try designing your parts with a smaller tolerance to compensate for the changes in your printer's hardware.
GregValiant 1,490
Given a line width of 0.40 and a 10mm cube - Cura's Outer Wall toolpath will be 9.6 by 9.6. Adding 1/2 line width to each side of the cube that comes out to your model dimensions of 10 by 10.
There are a couple of different settings to adjust that.
The problem I see here is that you had a workaround because your printer wasn't accurate. Now that it is accurate, you want Cura to make adjustments. That's fine, but it's always better to give Cura (any slicer really) the model you want rather than one that is "close except for...".
