- Solution
Thank you very much Dustin! I thought I had already tried all the possible combinations, but it seems when the surface mode is set to both AND the smooth spiralized contours is left un-checked then I finally get a smooth outer surface with no seam. I must have been chasing my tail a bit while trying all the different available combinations. Thanks again.
1
Dustin 53
Try changing "Surface Mode" to "Normal" or "Both"
(currently set to "Surface" in your settings)
