RE: Also realise that painting on the surface does not "define" what happens inside the volume, and the inside is actually what you want to affect.
I'm talking about painting one side of the object and that is reflected on the back of the object as well. Anything in between the two faces is changed.
I realize that you can load any geometry in and use it as a blocker but painting would be far easier
And yes I also realize what I'm suggesting is quite complicated but it would be great to be able to change the infill this easily.
Another thing to think about is painting on the surface and then just specifying the depth that the change goes to.
Eg. If I paint the surface of a block and specify 5mm the block changes from the surface down to 5mm and with say an irregular shape with different depths it changes down to 5mm but if it is thinner within the area specified it just uses the back of the object for that depth
ahoeben 2,047
You are "abusing" the support blocker to easily create blocks and then change them using the "per model settings" tool, but you can load in any geometry to use instead of those blocks.
I know that is not the same as painting, I know, but painting like that either depends a lot on the topology of the model, or it is actually quite complicated to implement. Also realise that painting on the surface does not "define" what happens inside the volume, and the inside is actually what you want to affect.
