Hi apologies I should have said that this problem only occured after upgrade to 5.3.0. They open fine as projects with previous versions of Cura.
- 11 months later...
Hi All, I tried all the fixes in this thread but they didn't work for me.'
The solution in this case was because the slicer that made the file (Bambu Slicer) does not output standards-comlpiant 3MF files. I ended up installing Bambu Slicer in a virtual machine, then opening the .3mf that way, and then exporting it again as a " Generic 3MF "), which then opened properly in Cura.
The fix is outlined in this thead:
GregValiant 1,318
Not all 3mf files are project files. A 3mf file is an archive (similar to a Zip folder) and contains sub-folders. In a project file one of those sub-folders will be "Cura" and it will contain the Cura settings.
You can use an app like 7-Zip to open any 3mf archive and view what it contains. If there is a Cura folder in it then it should open as a project. If there isn't, then it will open as the model only.
