wood PLA prints keep clogging
Posted (edited) · wood PLA prints keep clogging
So far it seems like clogging happens in a very arbitrary way. Image attached is showing only a few of the prints that failed because of clogging.
So far I've tried:
- printing a temperature tower to find the best temperature
- tweaking print speed, flow rate, fan speed, combing, temperature, retraction
- trying to manually unclog the printcore during printing
With all these methods, i've been able to make prints last longer before they clog, but it seems like manually unclogging the printcore is the only reliable way that has made successful prints.
I'm using a 3 extended with a 0.8mm printcore. Anything I might be missing? Will newer versions of printer, say S5, inherently better for printing wood PLA?
Edited by sycamore361
    Posted · wood PLA prints keep clogging
    It might be wet? Generally wood filaments are VERY sensitive to moisture.
    I would say you need to use a larger print core.. because wood filament usually has big chunks in it.. but 0.8 should be more than enough there..
    Maybe double check your front cooling fan is working correctly and didnt get clogged up during these tests?
    relative humidity has been under 30% most of the time. should i bring a dehumidifier...?
    the fan is working probably. sometimes i notice that the prints actually last longer if the fan speed is not too high... makes me wonder what happens in the printcore, there might be a sweet spot where the fan is JUST ENOUGH to produce a constant flow
    Is it possible to pause in the middle of a print to clean the inside of a printcore? after dozens of tries this looks like the only solution
    Not that I am aware of.
        • 56 replies
        • 34 replies
