Cura 5.3 : Issues in start gcode
Posted · Cura 5.3 : Issues in start gcode
I use some replacement parterns in my start gcode :
{used_material,x) -> adds Tx Material used by the tool
{used_nozzle_size,x) -> adds Tx Nozzle size used by the tool
It was working fine with Cura 5.2.2.
Upgrading to 5.3 has broken the replacement pattern for these two settings.
Is there a way to fix it ?
    Posted (edited) · Cura 5.3 : Issues in start gcode
    I think you used {material_used,x} before. {used_material,x} never was something that Cura recognized.
    Similarly, you should use {machine_nozzle_size,x} not {used_nozzle_size,x}.
    Edited by ahoeben
    Hi @ahoeben
    Thanks for your feedback. Indeed {material_used,x} and {machine_nozzle_size,x} are in the Settings and replacement patterns list. I've used them.
    I have realized that {used_material,x} and {used_nozzle_size,x} are functions generated by a plugin or a script written by my vendor to accommodate IDEX on Cura.
    I need to go deeper in the implementation
    Edited by V3DPrinting
    Sorry, I was mistaken in my previous reply.
    {machine_nozzle_size, x} should work just like that (with the extruder nr filled in)
    {filament_amount} is replaced by a list, so you cannot specify an extruder number.
    For the full list of replacement patterns, see http://files.fieldofview.com/cura/Replacement_Patterns.html
    Also I have realized that the 2 functions created by my vendor works fine except if I disable the extruder 1.
    Thanks for the link !
        • 56 replies
        • 34 replies
